[NEW] FFmpegForge – A Powerful FFmpeg GUI for Video, Audio and Image Conversion
Hi everyone!
I'd like to introduce FFmpegForge, a Windows graphical user interface for FFmpeg that I've been developing.
FFmpegForge is designed to make FFmpeg's extensive multimedia conversion capabilities accessible through a modern, user-friendly interface, while giving users the freedom to choose their preferred formats and encoders.
Unlike converters that rely on a predefined selection of output formats, FFmpegForge dynamically detects the formats, codecs, and encoders available in FFmpeg.
This is one of the main ideas behind the project: instead of restricting users to a small number of commonly used formats, FFmpegForge aims to expose the extensive capabilities of FFmpeg directly through its graphical interface.
Main Features
Dynamic FFmpeg Format and Encoder Detection
FFmpegForge automatically retrieves the available formats, codecs, and encoders from FFmpeg.
- No fixed, hardcoded list of supported formats.
- Access to common and uncommon multimedia formats.
- Automatic discovery of capabilities provided by the FFmpeg build.
- Support for newly available formats and encoders as FFmpeg evolves.
The available capabilities depend on the FFmpeg build being used.
Video Conversion
Convert video files using the formats and video encoders available in FFmpeg.
Users can select their preferred output format and video encoder instead of being restricted to a small collection of predefined conversion profiles.
Audio Conversion
FFmpegForge also provides access to FFmpeg's audio conversion capabilities.
Users can choose from the available audio formats and encoders, including less common options supported by FFmpeg.
Image Conversion
Image conversion is also part of FFmpegForge.
The application exposes FFmpeg's available image formats and encoding capabilities, allowing users to work with both common and less frequently used image formats.
Freedom of Format and Encoder Selection
One of FFmpegForge's main goals is to give users more control over their conversions.
Rather than deciding in advance which formats and encoders users should have access to, the application lets them explore and select from the capabilities detected in FFmpeg.
This makes FFmpegForge useful not only for everyday multimedia conversions but also for users who need to work with unusual or specialized formats.
Modern Windows Interface
FFmpegForge features a modern dark-themed graphical interface designed to make FFmpeg easier to use without requiring users to manually write command-line instructions.
An Important Note About Format Compatibility
Although FFmpegForge dynamically discovers FFmpeg's available formats and encoders, this does not mean that every possible conversion combination is supported.
Some formats are limited to decoding or encoding, and certain containers only accept specific codecs.
Actual conversion capabilities depend on FFmpeg's technical limitations, the selected formats and encoders, and the FFmpeg build being used.
Why I Created FFmpegForge
My goal was to create a graphical interface that doesn't unnecessarily restrict the capabilities of FFmpeg.
FFmpeg supports an enormous range of multimedia formats and codecs, but many of these capabilities can be difficult to access without using the command line.
With FFmpegForge, I wanted to provide a more accessible way to explore and use these capabilities while maintaining flexibility for users who need more than standard conversion presets.
The project is under active development, and I'm continuing to improve it.
Screenshots
[Insert your FFmpegForge screenshots here]
Download
[Insert your official download or GitHub link here]
Feedback Welcome!
I'd really appreciate feedback from the VideoHelp community, especially from users who are familiar with FFmpeg or other FFmpeg-based graphical interfaces.
I'm particularly interested in your opinions on:
- The dynamic detection of FFmpeg formats and encoders.
- The ability to access uncommon video, audio, and image formats.
- The interface and overall usability.
- Features or improvements you'd like to see in future versions.
If you already use another FFmpeg GUI, I'd also be interested in knowing what you think FFmpegForge could do differently or better.
Constructive criticism, suggestions, and bug reports are all welcome.
Thanks for taking the time to check out FFmpegForge!
https://github.com/Aaronstanley78/FFmpegForge
Results 1 to 30 of 38
Last edited by Aaronstanleyfx; 19th Oct 2026 at 05:43. Reason: More suitable presentation of the software
Hi everyone!
I'm excited to announce the release of FFmpeg Forge v1.1.1!
This new version brings several exciting features and improvements for video enthusiasts, content creators, and anyone looking for a powerful yet easy-to-use FFmpeg graphical interface.
FFmpeg Forge is a project I've been developing to make video and audio processing more accessible, without having to deal with complicated command lines, while still offering advanced customization options.
With version 1.1.1, I've introduced NVIDIA RTX AI video enhancement, DLSS Super Resolution, advanced video upscaling algorithms, immersive audio processing, and much more!
Here's a closer look at what's new.
NVIDIA RTX AI Video Enhancement
FFmpeg Forge now supports NVIDIA's AI-powered video enhancement technologies.
RTX Video Super Resolution (VSR)
Improve video quality using AI-powered upscaling and compression-artifact reduction.
Choose between four quality levels, from Low to Ultra, and upscale videos by ×2, ×3, or ×4.
RTX TrueHDR
Convert SDR videos into HDR10 with adjustable contrast, saturation, middle gray, and peak brightness.
The output uses 10-bit video with BT.2020 and PQ metadata for HDR-compatible playback.
DLSS Super Resolution (NVIDIA NGX AI)
FFmpeg Forge also supports NVIDIA DLSS Super Resolution with several processing modes.
DLAA, Quality (×1.5), Balanced (×1.72), Performance (×2), and Ultra Performance (×3).
⚙️ Three RTX Processing Engines
FFmpeg Forge can automatically select between three different processing engines depending on what's available on your system.
1. Built-in NVIDIA Driver Engine
Uses ForgeRTX.exe through D3D11 and NVIDIA driver extensions, similar to the technology used by Chrome, VLC, and mpv.
This engine works directly with compatible NVIDIA RTX GPUs without requiring additional SDK installations.
Simply enable RTX Video Enhancement in the NVIDIA App.
2. FFmpeg NVIDIA RTX Filters
Supports vsr_cuda, vsr_drv_cuda, truehdr_cuda, truehdr_drv_cuda, isr_cuda, and dlpp_drv_cuda, depending on your FFmpeg build.
The visual editor also provides access to the available filter parameters for more advanced customization.
3. RTXVideoProcessor
Optional integration with RTXVideoProcessor, based on NVIDIA's official RTX Video SDK.
Supports VSR ×2 and TrueHDR with NVENC encoding.
You can place RTXVideoProcessor.exe inside C:\FFmpeg\bin\ or locate it manually through the application.
GitHub: https://github.com/DrC0ns0le/RTXVideoProcessor
Advanced Video and Image Upscaling
This version also introduces several additional scaling algorithms for both videos and images.
AMD FSR 1, NVIDIA Image Scaling (NIS), Snapdragon Game Super Resolution (SGSR), Anime4K, xBR, hqx, Integer Scaling, Nearest Neighbor, Sharp Bilinear, BCAS, EWA Lanczos Sharp, Lanczos, Bicubic, and Spline.
GPU acceleration through libplacebo and Vulkan is enabled by default when supported.
The FSR, NIS, and SGSR shaders are embedded directly into FFmpeg Forge, so there's no need to download additional shader files.
A full FFmpeg build with libplacebo support is recommended for these features.
Immersive Audio – Dolby Atmos and DTS:X Speaker Layouts
FFmpeg Forge v1.1.1 introduces advanced multichannel audio configurations.
Available speaker layouts include 5.1.2, 5.1.4, 7.1.2, 7.1.4, 7.1.6, 9.1.4, 9.1.6, and 22.2.
These configurations are available in Audio Settings → Channels.
Audio can be exported as discrete multichannel PCM 24-bit or Opus, supporting up to 24 channels.
Automatic Immersive Audio Upmixing
One of the features I'm particularly excited about is the new automatic immersive audio upmixing system.
FFmpeg Forge can transform stereo audio into a multichannel mix designed for immersive speaker configurations.
Dialogue and lead vocals are directed toward the center speaker.
Instruments are distributed across the front, wide, and surround channels.
Bass and kick drums can be routed to the LFE channel.
Reverb, ambience, cymbals, and spatial details can be distributed across surround and height speakers.
Four processing styles are available: Auto, Music, Cinema, and Live Concert.
The application automatically selects a compatible audio codec when necessary.
This feature creates a channel-based immersive mix rather than native Dolby Atmos object-based audio.
Dolby Atmos and DTS:X Passthrough
FFmpeg Forge can also preserve existing immersive audio tracks without re-encoding them.
Supported passthrough formats include Dolby TrueHD Atmos, Dolby Digital Plus Atmos (E-AC-3 JOC), and DTS:X.
The original audio stream is preserved bit-for-bit when passthrough is used.
Please note that FFmpeg itself cannot encode native Dolby Atmos objects or DTS:X metadata.
Improved Compatibility and Error Handling
I've also improved how FFmpeg Forge handles compatibility issues.
The application now provides clearer messages when no compatible NVIDIA RTX processing engine is available.
It also warns users when certain features require a specific FFmpeg build or when RTX TrueHDR is combined with an incompatible 8-bit codec such as H.264.
⚙️ All the Existing FFmpeg Forge Features Are Still Here!
In addition to these new features, FFmpeg Forge continues to offer a wide range of video and audio processing capabilities.
Support for the output formats and encoders available in your FFmpeg build.
Apple ProRes and Avid DNxHR profiles.
Custom video resolutions without predefined limits.
More than 500 FFmpeg filters accessible through a visual editor.
Advanced encoding options and customizable presets.
Batch processing with drag-and-drop support.
Extensive control over video and audio conversion.
My goal is to offer the flexibility of FFmpeg through a convenient graphical interface, without restricting users to a few basic conversion options.
Requirements for NVIDIA RTX Features
An NVIDIA RTX GPU and a recent NVIDIA driver are required.
RTX Video Enhancement should be enabled in the NVIDIA App for the built-in processing engine.
DLSS Super Resolution requires an FFmpeg build containing NVIDIA NGX filters. If these filters are unavailable, FFmpeg Forge can fall back to RTX Video Super Resolution.
RTX TrueHDR requires a compatible 10-bit output codec such as HEVC, AV1, VP9, ProRes, or DNxHR HQX.
Some advanced scaling algorithms require a full FFmpeg build with libplacebo and Vulkan support.
Installation
Installing FFmpeg Forge is straightforward.
Step 1: Place ffmpeg.exe and ffprobe.exe inside C:\FFmpeg\bin\. A full FFmpeg build is recommended.
Step 2: Extract FFmpegForge.rar into C:\FFmpeg\.
Step 3: Launch FFmpeg Forge and start exploring its features!
I'd Really Love to Hear Your Feedback!
FFmpeg Forge is a project I'm actively developing, and I'd genuinely love to hear what the VideoHelp community thinks about it.
I've put a lot of time and effort into this software, and my goal is to keep improving it with each release.
Whether you're an experienced FFmpeg user, a video encoding enthusiast, or someone simply looking for an easier way to convert and enhance videos, your opinion matters to me.
I'm particularly interested in knowing what you think about the interface, the available features, and the overall user experience.
Do you find FFmpeg Forge easy to use?
Which features do you find the most interesting or useful?
Is there anything you think should be improved or redesigned?
Are there any features you'd like me to add in future updates?
Have you encountered any bugs or compatibility problems?
And for those of you who have used other FFmpeg graphical interfaces, how do you think FFmpeg Forge compares?
Please don't hesitate to share your honest opinions, whether positive or negative.
Constructive criticism is always welcome, and I believe it's one of the best ways to improve a project.
Even if you only try the software for a few minutes, I'd be very interested in hearing your first impressions.
I'd also love to know if FFmpeg Forge is something you could see yourself using regularly, and what would make it more useful for your workflow.
Your suggestions and feedback could directly influence the features and improvements included in future versions.
Thank you to everyone who takes the time to download, test, and share their thoughts about FFmpeg Forge.
I really appreciate your support, and I'm looking forward to hearing what you think!
Enjoy FFmpeg Forge v1.1.1, and happy encoding!
Download new version 1.1.1 here: https://github.com/Aaronstanley78/FFmpegForge/releases/tag/1.1.1 -
Update 1.1.3.a
️ CRF for H.264 and H.265 NVIDIA NVENC: when the video codec is "H.264 GPU NVIDIA (NVENC)" or "H.265 GPU NVIDIA (NVENC)", a new "CRF NVENC" field appears in Video settings. Type any value from 1 to 51, like the CRF of x264 and x265.
1 gives the best quality and the biggest file, 51 the smallest file. Good values are 18 to 23 for H.264 and 20 to 26 for H.265.
0 keeps the automatic mode: the value comes from the Quality setting, as before.
A hint under the field tells you what the chosen value means (very high, high, medium or low quality).
The value is used as NVENC constant quality (FFmpeg rc vbr with cq), so the file size follows the picture, like a real CRF.
It works everywhere FFmpeg Forge encodes with NVENC: normal conversions, Scale (the screen quality option no longer changes your value) and SeedVR2.
A bitrate above 0 still takes priority over the CRF.
Your CRF is saved with your settings.
⚙️ Requirements
An NVIDIA GPU with NVENC (GeForce GTX 10 series or newer) and a recent driver.
Download
FFmpegForge-1.1.3a-Portable.rar (about 204 MB): everything included, FFmpeg Forge 1.1.3a with FFmpeg 9.0.2 full and ForgeRTX. Extract the whole archive anywhere and run FFmpegForge.exe.
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/1.1.3.a -
Looks like pure AI slop, even your original post (that whatever AI wrote for you), you couldn't be bothered to fill in the placeholder text it left for you.
Your github repo has obvious AI tells, as does your readme. You don't disclose it, presumably out of shame. And your readme again has broken links and 404 images, couldn't you be bothered to even check what the AI wrote for you? Your Github avatar is AI slop too.
If you can't be bothered to even write your own post about it, and you can't be bothered to write the software itself, why should we be bothered? ��
Assuming it's Claude, why are you calling Claude "I"?
"I" have been developing this, yeah right �� -
Yes, FFmpegForge was entirely coded with Claude. And?
I'm not ashamed of using AI, and I don't see why I should be. I had an idea, guided the development process, requested features and improvements, fixed issues with Claude's help, and personally tested the software before releasing it.
I never claimed to have manually written thousands of lines of code.
If you've found broken links or documentation issues, thanks for pointing them out. Those are valid criticisms, and I'll address them.
But calling someone's work "AI slop" without even discussing how the software actually performs says more about your attitude than about the software itself.
You seem more interested in how the software was created than whether it actually works or is useful.
AI is a tool. Using it doesn't automatically make a project worthless.
Constructive criticism is always welcome. Condescending remarks, not so much.
And if FFmpegForge isn't for you, that's perfectly fine. Nobody is forcing you to use it. -
Wanted to test the effectiveness of the used Optiscaler GLSL script with different settings on non cg content.
Since I could not find a preview option: A preview function with a before<>after (maybe also diff) preview would be helpful when trying to adjust filtering settings.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Roph, you are sadly misinformed about what AI-guided development is all about. You should do some research before you embarrass yourself further. And as ctsdh0 said, who cares if the application works well.
Hi,
First of all, I wanted to say a huge thank you for creating FFmpegForge. I am currently using version 1.1.3a, and it is a truly impressively put-together program! I especially appreciate that it is a proper portable version that works flawlessly no matter where it is placed on the computer. That kind of flexibility is amazing.
Since I am very interested in DSD audio, I have a small feature request. The latest FFmpeg nightly builds now include a native DSD encoder and fully support .dsf and .dff extensions.
Would it be possible to add these two options to the audio encoder dropdown menu in a future update? It would be a fantastic addition for high-end audio processing.
Thanks again for your hard work and for consideration!
Best regards -
Hello everyone, and thank you for your support.
A video preview feature is planned for a future update I am currently working on it. Ivek167, thank you for your suggestion to add a DSD encoder to the "audio" section this will be included in a future update. I’m glad you like the software I am doing my absolute best to create a truly comprehensive FFmpeg-based program. For those with a GitHub account, please consider starring the repository if you support and enjoy the software. It’s a pity that VideoHelp hasn’t added it to their software list I submitted a request, but it still hasn’t appeared there.Last edited by Aaronstanleyfx; 30th Oct 2026 at 01:45.
Nothing - however this is good practice to inform community about AI use.
Well... you are not ashamed but also seem you are far from being proud of fact AI use...
True, you never claimed that you manually written thousands line of code however those thousands line of code was created by using other people work, frequently without permit - LLM's stealing other people work - this well known fact - so you personally not stealing but you are simply taking benefits from thievery of others.
Yes, AI is tool, tool build on humans knowledge - those LLM was trained using OTHER people work and companies running those LLM's didn't payed humans single cent for their work, effort and knowledge - that's why AI is thief and this must be pointed clearly.
But this is beyond you - you must accept various comments and remarks also those pointing that your development is based on knowledge stolen from other people... -
You can use SoX for DSD, also foobar2k supports DSD...
https://github.com/rossturk/sox-dsd
https://github.com/turbulentie/sox-dsd-win
This seem the most regularly maintained SoX with DSD support for - https://codeberg.org/sox_ng/sox_ng
https://codeberg.org/sox_ng/sox_ng/wiki/DSD-Encoding
It is good to mention that DSD support was possible thanks to HUMAN work - HUMAN behind DSD code is Måns Rullgård not some LLM - LLM's are not aware of Nyquist rate concept...Last edited by pandy; 29th Oct 2026 at 13:49.
⚠️ Beta version: please report anything strange in the Issues.
✨ New
Live before / after preview: while a video exports, a preview window opens and shows the original frame and the final rendered frame (Scale, FSR, OptiScaler, Denoiser, filters, RTX, SeedVR2, VisionNext…).
↔️ Slider mode: drag the line (or use the arrow keys) to wipe between the original and the final picture. Side by side mode: both pictures next to each other (Space switches between the two modes).
⏱️ The preview updates about once per second of video. The frames come from the same FFmpeg command as the export, so the video is decoded only once and the export is barely slower.
☑️ Option "Live before / after preview while exporting (beta)" in Video settings, ticked by default. If a file cannot be previewed, it is converted normally without the preview.
DSD export: new audio formats DSF (Sony DSD Stream File) and DFF (Philips DSDIFF), and new audio codecs DSD64 2.8 MHz and DSD128 5.6 MHz.
FFmpeg can read DSD but cannot write it, so FFmpeg Forge does it itself: FFmpeg prepares the audio (trim, channels, volume, filters, oversampling), then FFmpeg Forge's 1 bit 7th order delta sigma modulator writes the DSD stream. Measured THD+N (20 Hz to 20 kHz): about −113 dB in DSD64 and −124 dB in DSD128.
Mono, stereo, 3.0, quad, 5.0 and 5.1 (DSF and DFF hold up to 6 channels). 0 dBFS is written at 50 % modulation, the SACD reference level.
✅ Everything from 1.1.4 is still there: Upscale VisionNext, SeedVR2, OptiScaler, Denoiser, Scale, NVIDIA RTX AI, CRF NVENC, Spatial Music, filters and all formats.
Downloads
FFmpegForge-1.1.5b-Portable.rar (about 204 MB): everything included, FFmpeg Forge 1.1.5b with FFmpeg 9.0.2 full and ForgeRTX. Extract the whole archive anywhere and run FFmpegForge.exe.
FFmpegForge-1.1.5b.rar (about 0.6 MB): normal edition for your own FFmpeg (C:\FFmpeg\bin or next to the .exe).
ℹ️ The live preview needs FFmpeg 4.4 or newer (included in the portable edition).
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/1.1.5b -
Why? Do you inform them about your lint utility or your text editor?
That's an interesting point. I asked Claude about it:True, you never claimed that you manually written thousands line of code however those thousands line of code was created by using other people work, frequently without permit - LLM's stealing other people work - this well known fact - so you personally not stealing but you are simply taking benefits from thievery of others.
> For coding, do you observe licensing and copyright or not?
● Yes, I try to observe licensing and copyright, though I can't guarantee it every time.
- I avoid reproducing substantial copyrighted material word for word, whether it's code, book text, or lyrics.
- When you bring in third-party code, I keep its license headers and attribution, and I flag license conflicts,
for example GPL code going into a closed-source program.
- The limit is that I have no way to check my output against every existing source, so an occasional memorized
snippet could slip through without my knowing.
Claude says:...your development is based on knowledge stolen from other people...
Where the critics have a real point:
- Anthropic was sued by authors over training data. In June 2025 Judge Alsup ruled that training on lawfully acquired books was fair
use, but that downloading copies from pirate sites was not. Anthropic then agreed to a settlement of about $1.5 billion.
- Consent and payment for the creators whose work was used are a legitimate, unresolved grievance. That's an argument about
what's fair, not just about the law.
Where "theft" and "stolen property" go wrong:
- Copyright infringement isn't theft in law. The US Supreme Court said as much in Dowling v. United States (1985): infringed copies
are not "stolen goods".
- Whether training on copyrighted material is legal is still contested. Early rulings (Alsup in the Anthropic case, Chhabria in
Kadrey v. Meta) found training to be fair use on the cases before them. Other cases are still open, so "it's settled theft" isn't
accurate. Neither is "it's settled legal."
- A user isn't receiving stolen property. Liability for a user would come from publishing output that reproduces someone else's
protected work. That's the same duty you have with code from Stack Overflow, a forum post, or a book.
- Anthropic's commercial terms include copyright indemnity for customers against claims over outputs.
Training on copyrighted work is a live legal question, and early rulings have mostly found it fair use. Where Anthropic used pirated
books, a court said no and Anthropic paid for it. Using the tool doesn't make anyone a receiver of stolen goods. What matters is
whether you publish something that copies someone else's work, and that was true before AI.
Your over-the-top rhetoric is exposing you now. Also many top developers of important and respected apps are using AI coding tools now. There is nothing to be ashamed of.It is good to mention that DSD support was possible thanks to HUMAN work - HUMAN behind DSD code is Måns Rullgård not some LLM - LLM's are not aware of Nyquist rate concept...
Claude says:
Nyquist rate: for a signal band-limited to B Hz (no energy above B), the Nyquist rate is 2B, the minimum sampling rate at which the
signal can be reconstructed exactly from its samples (Nyquist-Shannon sampling theorem). In practice you must sample strictly above
2B: a sinusoid at exactly B can be lost if every sample lands on a zero crossing. Reconstruction is ideal sinc interpolation
(Whittaker-Shannon). Sampling below 2B causes aliasing: components above fs/2 fold back and show up as false lower frequencies, and
once aliased they cannot be separated out. That is why an anti-aliasing low-pass filter goes before the sampler. Do not confuse it
with the Nyquist frequency, which is half a given sampling rate (fs/2), the highest frequency that rate can represent. Example: CD
audio samples at 44.1 kHz to carry a 20 kHz band; the gap between 20 kHz and the 22.05 kHz Nyquist frequency leaves room for the
anti-aliasing filter's transition band.
One more point worth having: the theorem requires the signal to be strictly band-limited. Real signals never
quite are, so practical systems oversample and filter, rather than sampling at exactly 2B.
I suggest you start a new thread for this to avoid further polluting this excellent thread. Finally, you may not have considered this, but if you go around accusing people of receiving stolen property you open yourself to defamation lawsuits.Last edited by Columbo; 29th Oct 2026 at 16:49.
That was Ivek167.Selur, thank you for your suggestion to add a DSD encoder ..
about the preview: I had more a filter preview in mind (maybe by leveraging ffplay or libav), but thanks for the 'encoding viewer / comparer'.
Poor argument - ask LLM's why - ask about difference between text editor and LLM (i give you a hint - syntax highlighting is not AI).
Firstly - licenses usually not covering LLM training - they are tailored for human use not machine use, secondly LLM's are guided to try not to do some things but as we already know they also frequently ignore those guidelines and do forbidden things - recently we had large number of event when LLM violate law and hacked security of services to acquire data - that's why there is informal rush to create better protection also in laws against LLM.
Law and knowledge are lagging when compared to LLM's evolution speed.
How many of people creating something innovative is aware of fact that their work was used illegally by LLM? How many of them is able to fight against companies running LLM's?
So you generally quoting that indeed LLM's stealing other people work but if those people are reach and they can afford for lawsuit against big tech companies they can be payed for their work - good for you.
Good academic discussion only in wrong place - people feel there work was stolen, quoted by you LLM says about morality vs law and we all knows that LLM's are Super Intelligence due not using moral rules in their decisions - they are above human morality.
So what exactly exposing my "over-the-top rhetoric"?
And quoting wikipedia formulas quoted and recitied by LLM doesn't mean that LLM i AWARE of CONCEPT behind formula - i saw LLM code when LLM proposed generation of sinusoid 200kHz and used sampling 44100Hz, i saw multiple times when LLM's was unable to do simple ESTIMATION based on quite precision input data - some LLM's hallucination are even hilarious but still - this is pure syntax shuffling.
So once again pure argumentation mostly limited to providing quotes from LLM that prove my point.
You are barking wrong tree but this is your circus and not my monkeys - if you feel insulted then sue me - your LLM may prepare lawsuit for you - waiting patiently... good luck.
BTW Many forums and sites introduce rules to clearly mark AI generated content, some sites forbid or restrict such content - perhaps it is time for Videohelp to introduce new rules addressing AI? -
✨ New in 1.1.5
Upscale VisionNext without Visual Enhancer: VisionNext is now built in. Its model is VOSR 2.0 (one step 1.4B generative super resolution, CVPR 2026, Apache 2.0). Click "Install VisionNext model…" once and FFmpeg Forge installs the official VOSR code, the VOSR 2.0 weights with their VAE and DINOv2 encoder, Python and PyTorch CUDA in its own folder (VisionNext next to FFmpegForge.exe), then runs the model itself on your NVIDIA GPU.
GPU or CPU: tick GPU (NVIDIA CUDA, fast) or CPU (works without an NVIDIA card, much slower). The choice appears as soon as Upscale VisionNext is ticked.
Upscale factor ×1, ×2, ×3, ×4 and ×8, with tile size 256 or 512. The work grows with the output size: ×3 takes about 2 times longer than ×2, ×4 about 4 times and ×8 about 16 times. Very large outputs switch the VAE to tiles automatically so the GPU memory is not exceeded.
Videos are encoded directly, never picture by picture. With the built in engine, the video goes from the decoder to the model and straight into the final encoder: no picture files on disk and one single encode. With the Visual Enhancer engine, whose command line only reads pictures, FFmpeg Forge feeds it small batches of frames while the final encoder is already running, so there is still one single encode and no full frame sequence on disk.
⚡ Faster VisionNext: bf16 on the tensor cores with flash attention, all the tiles of a frame processed in one pass, and the same noise for every frame so there is no flicker between frames. Norms, tile blending and the colour fix stay in full precision. Triton is no longer needed (it does not exist on Windows), which fixes the "TritonMissing" error.
Denoiser IA: the Denoiser section is now a single checkbox. Tick it and FFmpeg Forge removes noise and film grain from videos and images with an AI network, for a clean and natural picture in the spirit of Neat Video. The AI is SCUNet (Swin Conv UNet by Kai Zhang et al., Apache 2.0), trained for real world noise: camera sensor noise, film grain and compression noise. A Neat Video style temporal stabilisation keeps the picture free of flicker.
Much faster Denoiser IA: the whole SCUNet network is captured once as a CUDA Graph and replayed in a single call per batch, instead of launching about 8,500 small GPU operations one by one. The window attention is fused into one GPU kernel, up to 8 frames are processed per pass, in fp16, with decoding, AI work and encoding running at the same time. If the GPU memory is full, the work size shrinks automatically, and the normal mode is used if CUDA Graphs are not available.
Live preview: the before / after window closes by itself when the export is finished, and it can no longer make an export fail. If its pictures cannot be written (TEMP folder cleaned by Windows or an antivirus, file locked), only the preview stops and the export goes on.
Fixes: clearer error messages for the built in VisionNext engine, a warning when the output is too large for H.264 NVENC (4096 px) or H.265 NVENC (8192 px), and picture sizes that are not a multiple of 8 now work with VisionNext.
✅ Everything from the 1.1.5 betas is included: live before / after preview, DSF and DFF in every channel layout (import and export), SeedVR2, OptiScaler, Scale, NVIDIA RTX AI, CRF NVENC, Spatial Music, filters and all formats.
⚙️ Requirements for the AI features
An NVIDIA GPU (CUDA) with a recent driver is recommended. Without one, the AI runs on the CPU, which is very slow.
About 3 GB of disk space for the Denoiser IA, and about 10 GB for VisionNext built in (24 GB of VRAM recommended, more for ×4 and ×8).
×3, ×4 and ×8 need the built in engine. For outputs larger than 4096 px choose libx264, libx265 or H.265.
Downloads
FFmpegForge-1.1.5-Portable.rar (about 206 MB): everything included, FFmpeg Forge 1.1.5 with FFmpeg 9.0.2 full and ForgeRTX. Extract the whole archive anywhere and run FFmpegForge.exe. The AI Denoiser and VisionNext install next to it.
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/1.1.5 -
✨ FFmpeg Forge 2.0.0
A brand new design: royal blue and gold premium dark theme, gold logo, rounded cards, gradient buttons and a blue to gold progress bar. The layout stays the one you know from 1.1.5: header on top, your files in the middle and every setting in one column on the right.
Python / ONNX AI: a new section where you import your own AI models and run them on every frame of your videos and images.
ONNX models (.onnx) run with ONNX Runtime GPU (CUDA) or on the CPU, NCHW or NHWC. Models with a fixed input size are tiled automatically.
PyTorch models (.pth .pt .ckpt .safetensors .bin) are loaded by spandrel: ESRGAN, Real ESRGAN, SwinIR, HAT, DAT, SPAN, SCUNet, NAFNet, Restormer, OmniSR and many more.
Python scripts (.py) with load(device) or process(img). The "Python template" button writes a ready to edit example.
The model scale (×1, ×2, ×4…) is detected automatically. Options: keep the original size, GPU or CPU, fp16 or fp32, tile size. It runs before Scale, RTX, SeedVR2 and VisionNext and keeps your format, codec, audio, trim and filters. "Install AI runtime" installs PyTorch CUDA, ONNX Runtime GPU and spandrel once.
PNG/JPG SEQUENCE: in Video settings, tick PNG (lossless, 16 bit when the render is 10 bit) or JPG (quality 2, full 4:4:4 colour) to export your video as pictures. Every frame of the final render is saved as name_000001.png… in a name_PNG (or name_JPG) folder next to the video, with every video option and AI effect applied: Denoiser IA, Python / ONNX AI, Scale, OptiScaler, NVIDIA RTX, SeedVR2 and Upscale VisionNext.
Denoiser IA models: choose the AI in a list. SCUNet (built in, real noise and film grain), Nomos8k HAT L (finest detail, very heavy), NomosUni DAT (strong denoising, natural look) or PurePhoto SPAN (light clean up, very fast). The ×4 models are brought back to the source size, so the picture is cleaned without changing its resolution.
Faster Denoiser IA: the whole SCUNet network is replayed as a CUDA Graph (one call per batch instead of about 8,500 small GPU launches), with fused window attention and up to 8 frames per pass.
Faster Upscale VisionNext: 2 frames per GPU pass on 20 GB cards and above, the bicubic pre resize runs on the CPU in parallel and the colour fix stays on the GPU. The pixels are exactly the same as before. Upscale factor ×1, ×2, ×3, ×4 and ×8, tile size 256 or 512.
The live before / after preview can no longer make an export fail: if its pictures cannot be written, only the preview stops and the export goes on.
Everything from 1.1.5 is included: VisionNext built in (GPU or CPU, videos encoded directly), SeedVR2, OptiScaler, Scale, NVIDIA RTX AI, CRF NVENC, DSF and DFF in every channel layout, Dolby Atmos and DTS:X layouts, Spatial Audio, filters and all formats.
An NVIDIA GPU (CUDA) with a recent driver is recommended. Without one, the AI runs on the CPU, which is much slower.
About 3 GB of disk space for the AI runtime (Denoiser IA and Python / ONNX AI), and about 10 GB for VisionNext built in (24 GB of VRAM recommended).
FFmpegForge-2.0.0-Portable.rar (about 206 MB): everything included, FFmpeg Forge 2.0.0 with FFmpeg 9.0.2 full and ForgeRTX. Extract the whole archive anywhere and run FFmpegForge.exe.
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/2.0 -
Yesterday I gave your software a try. The task was to reduce the size of a way too big of a video (MP4) file: 900 Mb with only 02:34 of running time. I chose to convert it to MKV and it worked very quickly - in 10 minutes the file was reduced to only 245 Mb. Excellent result. Also I really appreciated the slider "before" and "after" - it provides an instant and convincing visual benchmark to see whether the video quality is good.
Here is one suggestion for future editions. Would it be possible to make some options stand out for the newbies? I assume that many people would use the program with the same purpose - that is, to reduce the size of files. Maybe, a future release could incorporate a small pop-up message which is triggered right after the initial analysis of the video file. It could say something like "Hey, there! The file looks way too big. Would you like to reduce it without losing information? Here is one option - trimming it to ... Mb via MKV (or WebM) format. Conversion will take approximately ... minutes, ... seconds". Another option would be to clearly mark a preset option - for instance, make it a bright, clearly visible yellow button on the right. That way the user's attention will be grabbed by the button and she will see if this option fits her well.
By the way, I did not notice if there was an option to manually set a thumbnail for the video file after conversion. If this option is there, perfect. If not, maybe, it should be incorporated as well. Thank you for your important work. -
Thank you very much for your detailed feedback and kind words! I'm really glad to hear that the software helped you significantly reduce your video file size while maintaining good visual quality.
It's also great to know that you appreciate the before/after comparison slider. That's exactly why I included it to make it easier to evaluate the results visually.
Your suggestion about making compression options more accessible to beginners is an excellent one. I particularly like the idea of automatically suggesting an optimized compression preset after analyzing the source file, along with an estimated output size and processing time. This could definitely make the software more intuitive, especially for users who aren't familiar with video encoding settings.
I'll keep this idea in mind for future updates. A more visible preset or recommendation button could also be a nice improvement.
Regarding custom thumbnails, that's another interesting suggestion worth considering.
Feedback like yours is genuinely helpful in improving the software and making it more user-friendly.
Thanks again for taking the time to test it and share your experience. I really appreciate it!
FFmpeg Forge 2.1.0
Thanks to the feedback received on the VideoHelp forum, FFmpeg Forge 2.1 helps beginners make their videos smaller without having to understand compression settings, while keeping every option for advanced users.
Compression assistant
After you import a video, FFmpeg Forge checks whether it could be made much smaller. A large file alone is never enough: the assistant compares the real density of the video stream (bits per pixel and per frame, from ffprobe) with what a modern encoder needs for the same resolution and frame rate.
When a worthwhile reduction is expected, a small card appears above the file list, with no pop up: current size, estimated size, estimated reduction, recommended video codec, container, audio and conversion time. Three buttons: Apply recommended settings, Measure size and time, Ignore.
No recommendation is shown for videos that are already efficiently compressed (HEVC, AV1, VP9 at a sensible bitrate), for HDR videos, for very short clips or for files that cannot be analysed.
Recommended settings: H.265 (x265) at "Very high" quality, or H.265 NVIDIA NVENC for long videos when a working NVIDIA GPU is detected, AV1 for WebM. Resolution and frame rate are never changed. Audio that is already efficient (AAC, Opus…) is kept as is, without re encoding. Videos with several audio tracks or subtitles go to MKV with every track kept.
You stay in control: applying only fills the usual settings, every setting stays visible and editable, and nothing starts until you click CONVERT. Ignore the card, or turn the automatic suggestions off in Destination ("Suggest compression optimizations automatically").
✦ New Optimized compression preset: a gold button in Output format that analyses the selected video and applies settings adapted to it. If the video is already efficient, it explains why and lets you "Apply anyway".
Honest size and time estimates
Indicative estimate: an instant size range based on the source and the target encoder, clearly marked as indicative.
Measure size and time: FFmpeg Forge encodes three short samples (at 20 %, 50 % and 80 % of the video) with the recommended settings, at below normal priority, and extrapolates the real size and the real speed of your computer. In our tests, a 2 min 34 s H.264 video of 849 MB was measured at 132 to 161 MB and 10 to 14 minutes; the full conversion gave 146.7 MB in 12 min 50 s.
Time estimates also learn from your previous conversions (same codec, speed and resolution class). Without data, FFmpeg Forge says so instead of inventing a number. Estimates are always shown as estimates, never as guarantees.
Remaining time during the export: the file list and the status bar now show the progress and the time left ("38 % · about 30 s left").
Cover / thumbnail
New "Cover / thumbnail" option in Video settings: a frame of the converted video at the time you choose, or your own picture. It is added after the conversion, without re encoding the video. MP4 and M4V get cover art (shown by Windows Explorer and most players); MKV gets a cover.jpg attachment. Other formats (MOV, WebM, AVI…) do not support it reliably and are skipped with a message.
NVIDIA RTX Video in Video and Image
New "NVIDIA RTX Video" list (Off, ×2, ×3, ×4) in Video settings and Image settings, using NVIDIA RTX Video Super Resolution. For videos it is linked to the NVIDIA RTX AI section. For pictures it is new: a single picture (or a frame of a video) goes through the built in NVIDIA driver engine (ForgeRTX). Needs an NVIDIA RTX GPU with "RTX Video Enhancement" enabled in the NVIDIA App.
PNG/JPG SEQUENCE
The image sequence export in Video settings is now a simple "PNG/JPG SEQUENCE" option: tick PNG or JPG to export your video as numbered pictures, nothing ticked for a normal video file.
Unchanged and preserved
The live before / after comparison, the progress bar, cancelling, every preset, codec and format, the AI features (Denoiser IA, Python / ONNX AI, VisionNext, SeedVR2) and your saved settings work exactly as before.
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/2.1 -
I gave it a quick shot only:
It seems not to recognize interlaced footage - even when flagged as interlaced - and without manual interaction encodes it as progessive without suggesting deinterlacing. Adding the bwdiff deinterlacer manually works though, or same via Presets -> Video -- clean-up -> Deinterlace.
Other suggestion: The Presets->Video -- Color may also include 601-709 colormatrix/colorspace conversions (e.g. for upscaling SD to HD).Last edited by Sharc; 31st Oct 2026 at 18:48.
✨ FFmpeg Forge 2.1.5 for Windows
✨ [NEW] FFmpeg Forge 2.1.5 for MacOS
FFmpeg Forge 2.1.5 brings QTGMC deinterlacing for interlaced videos (DV, DVD, TV recordings, 1080i camcorders) and, for the first time, a portable edition for macOS, on Apple Silicon and Intel Macs.
Deinterlacing with QTGMC (Windows and macOS)
New "Deinterlacing" option in Video settings, with three choices: Off, QTGMC double rate (50p / 60p) and QTGMC same rate (25p / 30p).
Double rate turns every field into a frame: 25i becomes 50p and 29.97i becomes 59.94p, for the smoothest motion. Same rate gives one frame per original frame: 25i becomes 25p and 29.97i becomes 29.97p.
Field order: Auto uses the order written in the file (top or bottom field first). If motion judders back and forth, force TFF or BFF. Forcing an order also deinterlaces files that are not flagged as interlaced.
Only interlaced videos are processed. Progressive videos are left as they are, and the log says so.
QTGMC is QTempGaussMC from vsjetpack, running on VapourSynth R81 with its plugins (MVTools, znedi3, zsmooth, resize2, akarin, vszip, BestSource). It runs first, before every other effect, so the rest of the chain gets clean progressive frames. Trim, audio, PNG/JPG SEQUENCE, cover and every format keep working.
"Install QTGMC (VapourSynth)…" installs everything once: uv, Python 3.12, VapourSynth and the plugins at tested versions, about 150 MB. The installer checks that QTGMC loads before it finishes.
Until QTGMC is installed, FFmpeg's bwdif deinterlacer is used with the same settings, and the log says so clearly.
QTGMC is slow: it is the best quality option, not the fastest. On a plain conversion, bwdif is much faster.
New: FFmpeg Forge for macOS (portable)
A native Mac application with the same blue and gold design and the same layout as the Windows version: files in the middle, every setting in one column on the right, CONVERT at the bottom.
Portable: everything is inside FFmpeg Forge.app, FFmpeg included. Copy it to Applications, a USB stick or an external drive. Requires macOS 12 Monterey or later.
Included on macOS:
Video, audio and image conversion with the main formats and presets of the Windows version (MP4, MKV, MOV ProRes, DNxHR, WebM, GIF, MP3, FLAC, WAV, PNG, JPG, WEBP…)
Quality, encoding speed, resolution, frame rate, rotation, trim and destination
Filters: preset library and your own FFmpeg filters
Compression assistant: analysis, real measurement on 3 samples and Optimized compression
Cover / thumbnail, PNG/JPG SEQUENCE and QTGMC deinterlacing
Apple VideoToolbox hardware encoders (H.264 and H.265)
Drag and drop of files and folders, remaining time for each file
Not available on macOS yet: NVIDIA RTX Video, NVENC and every CUDA feature (they need an NVIDIA GPU), Denoiser IA, Python / ONNX AI, VisionNext, SeedVR2, Scale / OptiScaler, Spatial Audio and DSD export. The AI features on the Apple GPU are planned for a later version.
QTGMC on macOS needs macOS 15 Sequoia or later (the VapourSynth plugins for Mac are published for macOS 15). On older versions, bwdif is used.
Improvements (Windows)
NTSC frame rates (29.97, 59.94, 23.976) are now written as exact fractions (30000/1001, 60000/1001…) when a frame rate is set.
Unchanged and preserved (Windows)
The compression assistant, cover / thumbnail, NVIDIA RTX Video, PNG/JPG SEQUENCE, the live before / after comparison, every preset, codec and format, the AI features and your saved settings work exactly as before.
Downloads
Windows
FFmpegForge-2.1.5-Portable.rar (about 206 MB): everything included, FFmpeg Forge 2.1.5 with FFmpeg 9.0.2 full and ForgeRTX. Extract the whole archive anywhere and run FFmpegForge.exe.
FFmpegForge-2.1.5.rar (about 0.7 MB): normal edition for your own FFmpeg (C:\FFmpeg\bin or next to the .exe).
Denoiser IA models (HAT L, DAT, SPAN): use FFmpegForge-2.0.0-Denoiser-Models.rar, unchanged. Extract it next to FFmpegForge.exe (models folder).
macOS
FFmpegForge-2.1.5-macOS-AppleSilicon.zip (about 140 MB): for Macs with M1, M2, M3 or M4, with FFmpeg 7.1.
FFmpegForge-2.1.5-macOS-Intel.zip (about 164 MB): for Intel Macs, with FFmpeg 6.1.1.
First start on Mac: the app is not signed by Apple. Right click FFmpeg Forge.app, choose Open, then Open again. On macOS 15 and later, if it is blocked, go to System Settings, Privacy & Security, and click "Open Anyway". If macOS says the app is damaged, run this in Terminal: xattr -dr com.apple.quarantine "/path/to/FFmpeg Forge.app"
VapourSynth, vsjetpack and the plugins are not included in the archives: the installer downloads them from PyPI.
https://github.com/Aaronstanley78/FFmpegForge/releases/tag/2.1.5 -
[Attachment 94198 - Click to enlarge]
My wish for the main window.
Status bar - speed (frames per second), remaining time.Last edited by Zee; 2nd Nov 2026 at 04:30.
✨ FFmpeg Forge 2.1.6
FFmpeg Forge 2.1.6 brings a brand new cinematic design, SDR to HDR conversion (HDR10 and Dolby Vision 8.1), and new audio track tools requested by users: change only the audio of a video, or add audio tracks, without re encoding the picture.
New cinematic design
New header with original artwork (film reel, golden light streaks), a bigger gold logo, "FFmpeg FORGE" in large letters and a gold "VERSION 2.1.6" badge.
FFmpeg status pill in the header: a magnifier while detecting, a green check when FFmpeg is found, a red warning when it is missing. "FFmpeg location…" now has its own button with a folder icon.
Every toolbar button has an icon: Add files, Add folder, Remove, Clear all, Show command, Filter library.
New drop zone: film strip artwork, big logo, "Drop your files here", and coloured feature badges (Video, Audio, Image, AI Denoise, AI Upscale, Dolby Atmos, DSD).
New Activity Log: one line per message with a status icon (info, success, warning, error), the time and the message, details dimmed. New "Clear log" button. Double click or Ctrl+C copies a line, right click copies everything.
Gold icons on every settings section, icons on the VIDEO, AUDIO and IMAGE buttons, taller file list rows.
Status bar with a coloured dot (green ready, gold working, red error), Open folder and Cancel with icons, and a new blue to gold CONVERT button.
Dark title bar on Windows 10 and Windows 11.
SDR to HDR (Video and Image)
✦ New "SDR → HDR" option with a choice of peak brightness (600, 1000, 1500, 2000 or 4000 nits).
HDR10: H.265 10 bit, BT.2020 PQ, HDR10 static metadata (mastering display and content light level). VP9 or AV1 for WebM.
Dolby Vision 8.1: the same HDR10 picture plus Dolby Vision dynamic metadata, measured on every frame of your video and grouped by shot. It plays as Dolby Vision on Dolby Vision screens and as HDR10 everywhere else. MP4, M4V, MOV or MKV. Made with dovi_tool (MIT licence), included next to FFmpegForge.exe.
HDR pictures: PNG 16 bit with the HDR tag (cICP) or AVIF 10 bit, BT.2020 PQ. Shown in HDR by Chrome, Edge, Windows Photos with HDR turned on, and recent phones.
How it works: the SDR picture is placed in HDR with SDR white at 203 nits (the BT.2408 reference white), then the highlights are expanded up to the chosen peak. Only the brightness is expanded, colours keep their exact hue.
An HDR screen is needed to see the result: on an SDR screen, HDR files look dim or flat. Files that are already HDR are not converted again.
Audio tracks without re encoding the video
✦ New "AUDIO TRACKS (VIDEO UNTOUCHED)" section in the Video category, as requested by users.
"Keep the video as is": the picture is copied bit for bit, same quality, very fast. Only the audio changes, for example Opus to AAC or AC3 (choose the codec in Audio settings).
Original audio tracks: convert them, keep them as they are, or remove them. Every audio track is processed, not only the first one.
Add audio tracks from audio files or from other videos, with language (guessed from the file name: _fr, VF, english…), title, delay in milliseconds to resynchronise a track, and default track.
Added tracks are copied as they are when the output format accepts them, otherwise converted automatically (the log says so). Chapters and metadata are kept, and subtitles too in MKV.
Also included
QTGMC deinterlacing (from 2.1.5) and the NVIDIA RTX AI audio sync fix (from 2.1.0.1).
Cover / thumbnail now works on Dolby Vision and HDR files too.
Enjoying FFmpegForge? If you find it useful, please consider stars the project on GitHub! It helps more people discover this free software and supports its continued development.
This project is continuously evolving, and I'd really love to hear what the VideoHelp community thinksLast edited by Aaronstanleyfx; 3rd Nov 2026 at 11:11.
Linux needs projects like this. Congratulations for the project
